Using common swing brackets for use with 4- 4x4x8 posts and 1- 4x6x10 beam, at what angle do I cut the bottom of the 4x4 posts to sit flush on the ground?
    I did not cut mine, I was using wood trunks for the rustic look, but sank them in holes about a foot deep with concrete to help. But you could do a drawing and use triginometry - all the fun of sines and cosines from school...
    – Solar Mike
    Apr 30, 2020 at 5:14
  • try 45 degree angle
    – jsotola
    Apr 30, 2020 at 7:21
  • How much does your yard slope? In other words, nothing is going to sit perfectly flush so I think SolarMike’s suggestion to sink the posts is spot on. Apr 30, 2020 at 11:27
    N.B. putting "asap" in your question body is considered rude.
    – Haem
    Apr 30, 2020 at 11:30
Without knowing the design of the brackets this is impossible to answer, but rather than calculate angles using trigonometry, there's an easier way:
Assemble it, and sit it on the ground. Then use an offcut of 4x2 or whatever, laid on the ground next the posts to mark a line parallel to the ground on each one. Then take it apart, cut them, and re-assemble.
