House was built in 1985. On one of the exterior walls, there are two Federal Pacific service disconnects for my outside HVAC units. The label on the first one indicates it's an FPE model R160, which is the service disconnect for a 40A furnace/compressor. The label on the second one says FPE model R130, as the service disconnect for a 25A A/C compressor. There is a pair of fuses inside each pullout, one pair are Bussmann and the other pair is unreadable due to weathering. Both circuits are protected upstream by appropriately sized breakers in a GE panel.
I know Federal Pacific has a well-deserved bad reputation for the flaws with their Stab-Lok panels and breakers, but I'm unsure if that tainted the other product lines they were manufacturing in the mid 80s. Seeing as how neither of these is giving me any trouble, is there anything about having FPE gear on my house that I should be concerned about?
Even if there are no immediate concerns, when the day comes that I want to sell, should I expect an overzealous home inspector to (incorrectly?) call them out as needing replacement?
