I have limited space because all the cabinets were already setup long back. A Bosch front load washing machine (60cm (d) x 60cm (b) x 85 cm (h) is placed in this space. There is a gap of 60.5 cm from the top of the washing machine free as of now.
Can a portable countertop / tabletop dishwasher (http://levant.beko.com/dishwashers/dtc36810w/) of dimensions 59.5cm (h) x 55cm (b) x 50cm(d) be stacked on top of the front load washing machine? What's the best way to go about it and any precautionary measures needed?
Updated/Edited:
The dishwasher is not a Full size one but a table top dishwasher designed to be placed on countertops. Example below.
As there is limited clearance and only 1 cm gap left considering both the appliances height, am planning to place a plywood top of 10 mm thickness and size 60 mm by 60 mm on top of the washing machine with an anti slip map. Is this a feasible option or some other material will work? Will the washing machine be able to take the weight and handle any vibrations the countertop dishwasher may have?
