I am in the process of remodeling my laundry room. Next step is to replace the flooring.
Currently the flooring is old one sheet vinyl glued down on concrete. I want to find out the feasibility of using click together laminate flooring in this application. Note that there will be full size washer and dryer sitting on top of the laminate flooring. Is that recommended or should this be avoided?
Let me add here that I am not asking about the type of vinyl flooring that has engineered plywood, MDF or hard fiberboard on the bottom.
Or would I be better off in this application to use a product like a peel and stick vinyl planking. (The place I work at recently replaced all their floors in hallways, entrances and high traffic areas with something like this).
