My brother has a metal pancake box directly screwed into a 2x4. That same screw used to fasten the box is also being used to ground the box.
i.e metal pancake box screwed into the wood also has the ground wrapped around it.
I know ground screws inside the box must be green - I am more concerned over whether or not what I described above is safe.
Ground screws do not need to be green.
Though they sell some very cute green ones ten for a buck if you want them to be green.
Ground screws must be -32 thread pitch or finer, and must be threaded into the metal box. 10-32 is the "conventional" size. And most metal boxes have a hole tapped for a #10-32 screw for precisely that purpose.
This is visible as a hole slightly smaller than the normal mounting holes.
If you can't find it for love or money, likely someone has driven the physical mounting screw into that hole. Better boxes try to help deter this by putting the ground screw on a stamped "bung". That also gives the ground screw a place to go besides straight into the wall, but if someone misused the hole for a mounting screw, that problem will be solved :)
  • Thanks - I do plan on fixing this to conform to code - in the meantime is there any safety hazard or risk where I should fix this much sooner rather then later. – Andrew Apr 27 '20 at 23:23
  • One point of the 32 pitch is contact surface. A concern I would have is a screw through a hole holding the ground might not survive if the fixture experiences an impact, and may not maintain the ground. – NoSparksPlease Apr 27 '20 at 23:29
  • Yeah, that's the problem... the screw loosens up due to strain (this is all but guaranteed on a ceiling fan) and now your ground is intermittent. – Harper - Reinstate Monica Apr 27 '20 at 23:56
Screws that mount the box to the framing are not allowed to be used for grounding. There is a separate hole in most of the pancake boxes for a grounding screw, a 10/32 thread and you can pick them up at your home store. If there is conduit terminating in the box, that might serve as a ground.
    250.148(C) is the Code ref for this, BTW – ThreePhaseEel Apr 27 '20 at 23:08
