Good afternoon,
Im trying to hang two hooks in my garage ceiling to hang a bicycle. I used a magnetic stud finder and marked a bunch of points where it stuck.
To confirm, the studfinder is just picking up the screws correct? How do I determine where the beams run to drill into? Do the beams run up and down between the marking from the wall? Is this where the beams run:
Here's a photo of where I marked what the studfinder found. They're all roughly a foot apart, give or take an inch. The idea was to drill into two of the spots and horizontally hang the bike.
Thank you
