I bought a three step ladder for some alternative use. However, I need to remove the first bottom step, but don’t really know where to start. Is there a smart way to remove it, except for just cutting the wires that hold it?
3I’m voting to close this question because it does not appear to be about home improvement.– Jimmy Fix-itApr 25, 2020 at 13:48
Its about DIY and a way to improve my home, so I don’t understand your argument– WJAApr 25, 2020 at 13:50
You say "for some alternative use" in the post. If you explained what you intend to do, the community would embrace the question and perhaps give you some alternative ideas on how to accomplish your objective. Disassembling a ladder, in and of itself, does not relate to "home improvement".– Jimmy Fix-itApr 25, 2020 at 18:51
Watch that first step; It's a doozie.– Alaska ManApr 25, 2020 at 20:26
1I am Not taking sides. "the purpose of this channel" is specifically laid out in the rules and not a matter of opinion. It takes more than 1 vote, or one person, to close a question. It is not difficult to word it in a more rule friendly way or add the pertinent info in your comments to the body of the question. We want to embrace you and your question, meet us half way.– Alaska ManApr 25, 2020 at 21:20
1 Answer
Note the slots cut in the holes at which the supporting rods attach. The rods have a matching tang. It seems likely that you can fold the ladder in such a manner to allow the tang on the rod to align with the slot on the step which should then allow the rod to slip out..
It may be necessary to remove the other step to accomplish this, or you may be able to remove the desired step straight away.
Detail is missing for the main support rod.
Yes, it looks like the main support rod is peened over, which means you will likely need to cut the main support rod. Apr 25, 2020 at 13:47
The OP needs to be aware that the rod between the legs do offer some stability to the bottom of the ladder. When the step and rod are gone, the bottom of the legs can spread easier if they have to occasion.– JackApr 25, 2020 at 15:05
Not only that, but the weight rating of that type of step stool may be incumbent upon the steps sharing the total weight bearing capability equally among each other. Remove one and you may compromise the rest. We don't know what your "alternative use" is though.– JRaefApr 25, 2020 at 18:59
See my comment on question. I intend to use it as a trey for eating from the couch. Need to remove the first step to have space for my legs.– WJAApr 25, 2020 at 21:04
