I'd like to build a fitted bookcase into the corner of a gable end, such as in this mockup. Excuse the poor attempt, I've never used SketchUp before.
Obviously they should show shelves/dividers etc and a 45deg angled corner section between the two walls, but I figure this is good enough for this question.
I'm undecided at the moment whether the units would stop in line with the edge of the door, continue over the door (as depicted) or (very possibly) go down the other side of the door as well.
My semi-plan is to buy an Ikea Billy bookcase unit or two (probably the large corner unit they do), and see if I can fit it into the corner by cutting bits off and melding other bits on.
Maybe that's too ambitious and it'd be easier to work with two separate units and forego the 45deg unit between them, and just have them butt up at 90deg and have some wasted space hiding behind.
I have a "can do" attitude, am happy to buy some tools, but a decided lack of woodworking skills/experience.
Is this quite trivial? What tools and techniques are the best way to cut laminated chipboard (or whatever Billy is constructed from) without chipping and ruining the outer layer?
I've never owned a Billy before so at the moment I have no idea what they're made from or fasteners Ikea use and how easy it'd be to relocate them, etc etc.
Thanks!
