I need to run a coaxial cable (and one more cable like ethernet) by a doorway. The floor is raised approximately 0.65 inches.
I found D-line raceways, and also the floor raceways that are wide (so people don't trip on it). I'm not sure they will fit well because they are right by a raised floor. I also found baseboard cord channel which might be better but I'm afraid they are taller than the raised floor.
Picture (only one cable is shown but there will be two running left to right):
Any experience with this? Any idea what would be the best solution here? Breaking the floor is not an option. It should be something that won't require construction.
Thank you.
