My room get overheated by the evening sun. I have some blinds but its not really helping. I was wondering if putting some reflective insulation would help. Not removing the blinds but between the blinds and the glass.
The room is on 2nd floor so would prefer a solution that doesnt need outside modifications. Secondly, would prefer a medium term solution that I can possibly easily remove when I move.
Thoughts? Feedback? Anything I should be worried about? Less concerned that it might not look great from the outside - but if it keeps the room cooler, I would be happy. Thank you in advance.
    This stuff will definitely help but could also cause overheating and cracking of the glass. Perhaps white foam insulation boards instead; easily placed and removed... – Jimmy Fix-it Apr 21 '20 at 21:32
  • Is there anything you could add to the outside? – DMoore Apr 21 '20 at 21:39
  • Related: diy.stackexchange.com/q/7893/95658 – Doug Deden Apr 21 '20 at 22:11
  • Do you have shutters? Close em... – Harper - Reinstate Monica Apr 22 '20 at 0:03
  • @JimmyFix-it had a silly question about cracking glass - arent these safe for car windshields? is that because that glass i harder than regular window glass? – smk Apr 22 '20 at 12:26
