I'm trying to disassemble this cabinet so I can get underneath the bottom panel and clean it - has a nasty fishy smell underneath and will require a comprehensive clean.
From the pics you can see there are no screw or anything on the outside. From the inside you only see screw at the top left and right panels. I want to know since the bottom panel doesnt seem to be screw in or anything, how can I take it off.
Is it the case that the hole bottom assembly is done with adhesive. Therefore I need to unscrew the top, then pry the bottom panel out from the sides? Can you explain to me exactly how I should do it. I was pushing the bottom panel up yesterday but I thought it might snap.
Also the bottom panel had to holes which I thought maybe screw but on closer inspection it doesn't look like anything.
Thanks
