This is a century home and we are trying to restore as much as possible.The attic has a plastic vapor stapled to the rafters and some spots it jus hangs exposing the wood. would it be wise to staple the loose parts then install rigid foam boards over the plastic.
  • Plastic stapled to the rafters (run at an angle usually, and is what holds up the roof), or plastic stapled to the attic floor joists (run horizontally)? Makes a difference. – SteveSh Apr 20 at 15:25
