My kitchen is equipped for dual fuel range, with both gas and electric, with a 50A breaker, 6/3 + ground, and a corresponding receptacle to accommodate that wiring.
We are replacing our range with a gas unit, which only requires to be plugged into a "normal" nema 5-15p outlet.
How should I adapt my existing 6/3 wiring in the wall to serve this range? It seems incorrect to wire nut 12awg to the 6awg and replace the receptacle.
