I have a set of climbing holds that I would like to attach to a stone finished outside wall of a house.
It's a granite rock that I would be attaching the holds to, like this:
My preference is to avoid drilling into the wall, and I would rather glue the holds.
Could epoxy glue be a good choice for such project?
9
    Why do you want to avoid drilling? – Sneftel Apr 17 '20 at 17:22
    Do you know whether or not the stones are just thin decorative pieces affixed to a wall, or whether those are actual stones that are the wall? – Jimmy Fix-it Apr 17 '20 at 17:27
    I wouldn't trust climbing rocks only attached by glue, more than likely one will pop off at an inconvenient time and then someone gets hurt – depperm Apr 17 '20 at 17:35
  • I'm not sure that this is the best plan. Those flagstones are attached in such a way as to support themselves with the primary force acting on them being gravity with a force direction of straight down. If you attach climbing holds you are introducing a new element here which is an outward force that wants to pull the stone off the face of the wall. It's anyone's guess in my mind as to whether or not this installation of stones was done with that use in mind. My guess is that the answer is NO and you should come up with a different plan. – jwh20 Apr 17 '20 at 17:48
    @AlaskaMan a fall never hurt anyone, just stopping at the end. – Solar Mike Apr 17 '20 at 19:38
