I have 4 light fixtures on the exterior of the house (pictured blue=lights, green=switches). 2 of them are on a wall along the stairs, 2 are at installed on the ceiling of an overhang in front of the garage.
All 4 of these fixtures are controlled by two light switches, one upstairs in the main level of the house, and one in the garage right inside the door.
I would like to install a Ring Floodlight Cam on the garage light closest to the door, how would I take that one fixture off the circuit so that it always receives powerenter image description here?
    Can you post photos of the insides of all boxes involved please? Apr 17 '20 at 2:03
  • Does that include switches too or just light fixture boxes? Would I need to do every single fixture to verify? Apr 17 '20 at 2:30
  • You'll need the switches for sure, and at least one light fixture (if not two, or even all four) Apr 17 '20 at 2:33
  • Thank you! I'll do this first thing tomorrow! Apr 17 '20 at 2:35
  • Since there is no hot feed to the location, you'll need to run new cable to the RingCam location. Are you sure you want it permanently on? I would recommend installing a separate on/off switch for that one fixture. Apr 17 '20 at 15:27
You pretty much need to run a new cable to that outlet and re-wire the existing cable to bypass that outlet.
inspection of the outlets may reveal the possibility for a different option, but I'm not expecting it to.
