I recently discovered that I have an unfinished attic in a guest bedroom on the second floor of my house, above the garage. The overall area is behind the closet in the bedroom and is approximately 10x20' wide. It has 2x6 joists spaced 16" on center.
I was hoping to put some 2x4s across the joists and add some plywood across to make a floor and use this space for storage. However, I don't know how much weight I could safely store up there. There is even a electrical switch and bulb in the area suggesting that may have been intended to function as a storage space?
Would an attic like this support mild to moderate storage weight if a floor was added? Are there any safety issues or other general concerns I should have? Any advice would be much appreciated
Here are the pictures of the attic: Unfinished Attic Space - 10'x20'
