Wanting to remove this closet that is by my front door. Nervous that the wall that is parallel to the door is wall bearing. First time renovating.
[![enter image description here][1]][1]
[1]: https://i.stack.imgur.com/HdXz4.jpgenter image description hereenter image description here
    Do you know what is in the attic directly above the walls?can you take a picture?
    – Lee Sam
    Apr 15 '20 at 4:04
  • I have added what it looks like directly above. Apr 15 '20 at 14:17
  • what is the brick-looking platform in front of the former closet?
    Apr 15 '20 at 18:24
From the 2 images you've attached, this is not a load bearing group of walls. Feel free to remove all 3 of them.
  • I would agree not a load bearing wall.
    Apr 15 '20 at 14:50
  • Thank you. Appreciate the assist! Apr 15 '20 at 15:48
I'd expect more blocking in a load-bearing wall (more than none)
Corners always have lots of wood, but the purpose of that is just to provide somewhere to attach the lining.
    What is “lining”?
    – Lee Sam
    Apr 15 '20 at 5:25
  • It's the stuff that hides the studs: drywall, or wood paneling etc.
    – Jasen
    Apr 15 '20 at 5:29
Even without the attic picture, I would find it very, very unusual that any of these three walls are load bearing. It would be many times more unusual for the wall -parallel- to your front door (thus parallel to your roof framing) to be bearing.
Your attic picture shows that the roof is bearing on a continuous wall which is the exterior wall. There would be some very obvious change in the roof framing at the area of the closet walls if they were to be bearing walls.
To be most clear and direct: your closet walls are not bearing walls
