I have a 14.85 amp portable air dryer with a 20 amp plug - vertical/horizontal prong. Can i replace this plug to standard 15 amp both vertical prongs, and use safely on a 15 amp circuit? Assuming it will be used continuously for no more than 10 minutes?
I know about the 80% rule over 3 hours. But don't want to throw it out if it's reasonably safe.
Thanks for all the help. Not going to change it. I should have clarified that this is a animal blow dryer (dog). 10 kg. quite expensive.
