The base of the new ceiling light is a 30” x 9” rectangle. Mounting it as the bracket currently sits would look really bad—not at all square to the room.
I don’t need the hole moved much; maybe an inch would be enough. I tried looking for a bracket that might work but came up empty. Sometimes that’s because I can’t find it and sometimes it’s because it’s a bad idea.
Any and all help appreciated!
Here’s a picture of the bracket. The red line is roughly parallel to the wall.
ceiling bracket with square line
  • I had the exact same issue, don't won't to provide an ans without more information. How is the fixtures mounted to the outlet box? Does it have it own mounting plate that is attached to the outlet? Provide picture of mounting plate if there is one or describe how fixtures is attached to this outlet. Apr 12, 2020 at 2:10
You can try an adaptor (universal crossbar) (adjustable swivel crossbar)
Or just live with it as is?
enter image description here enter image description here enter image description here
    That looks like exactly what I need. I’m not sure why I couldn’t find it (although I did give up early thinking “it’s probably a bad idea and so no one makes it.”) Apr 12, 2020 at 0:17
  • you can get those at HD or Lowes. Apr 12, 2020 at 2:03
  • I'm a little surprised the fixture didn't come with one of these already...
    – mmathis
    Jun 15, 2020 at 13:22
