I need to hang a 60 lb tankless water heater on the back wall of my house located in California. The house was built in the 1940s and the exterior walls are stucco. The mounting bracket on the water heater unfortunately does not span the 16 inches I would need to get it securely into two studs. I can get it into one stud, but without making a new bracket I would have to do one side into a stud and the other directly into the stucco. I don't think this house uses wood sheathing under the stucco, so it's probably the thick type embedded in wire mesh. Is there a reliable anchor I can use to go into the stucco that would support at least half the 60 lb weight without pulling out? Keep in mind Southern California gets earthquakes now and then.
Yes- there are toggle bolts that can support 60#. The real issues is the stucco wall. Plus in earthquake area, the wall-mounted water heater should be mounted on solid support members.
A better way to mount the water heater is to have two horizonal wooden spans that are bolted to the studs behind the stucco wall with the proper size lag bolts into the studs. The purpose of the second span which is below the first spand is to provide support to the bottom section of the tank since it is now 1 1/2" from the wall. The water brackets are screwed into the top horizontal span.
And alternate method is use a 3/4 plywood panel, the width would span the two available joist and additional width to where you want to hang the water heater. The plywood would be mounted to the at the top and bottom of the plywood plate on the studs. Brackets of water heater easily screwed into the plywood sheet.
My preference is the 2x4, because your screws for the bracket will have more backing to screw into. With the plywood plate, only 3/4 of holding power.
Yes there are toggle bolts that will hold the weight, but would not recommend this in stucco for a suspended water heater.
  • I think you mean 30# for the bolt since the total weight is 60# and I don't know if that includes the water and plumbing so 120# might be closer to the installed weight. If gas powered, there might be increased seismic requirements.
    – Ack
    Apr 11, 2020 at 21:20
  • It's an outdoor tankless heater, so it's designed specifically to mount outside. It's a shame the manufacturer didn't make the mounting bracket 1" longer and put it on 16" centers!
    – Synthetix
    Apr 11, 2020 at 21:33
