We bought our 100 year old house “as-is” a year ago with various small cracks and a firm, but somewhat eroded foundation. This all needs to be addressed eventually, however, a large crack with leaning segment of the retaining wall is my current and primary concern. My intention is primarily to prevent failure from an earthquake or some other novel cause of pressure or compromise.
Currently I see myself laying somewhat of a raised footing without excavating below the existing wall (no existing footing for retaining wall), placing concrete blocks and filling them with concrete and rebar. I would also place concrete between the blocks and the existing wall to attempt to fill in the void that will be caused by building a level vertical wall in front of a leaning wall.
Since this will be only my second time working with concrete and the most substantial and permanent home improvement project that I have ever undertaken, I am here looking for any and all comments, advice, concerns, creative thought, first hand experience, and any and all reference to resources directly related to the task at hand.
The following may be extraneous, but is relevant if you have the time to read.
I could be wrong, but for the following reasons, I believe the factors that caused the issue are no longer at work: (1) I dug a ditch to install a drain and divert water from the foundation, but observed for a week before filling the ditch. Some of the heaviest rainfall of the year came down during that week and I saw very little filling that ditch. (2) the house had no gutters for atleast 2 years before we bought it and likely no proper drainage before that time leading to the removal of the gutter. (3) The sewer line comes out just above the leaning wall and in ‘96 it was transferred from septic to sewer with all plumbing exterior of the wall replaced. A wide shallow depression can be seen above ground where the pipeline is.
I’ve had three different quotes with three entirely different types of solutions suggested (all costs from memory). The first was to install I beams to support the wall in addition to some other work that I can’t remember but would help reset the wall to vertical ($30,000) along with the suggestion that I first install a French drain. The second was to seal the crack with an epoxy or similar and apply a sort of structural bandage perpendicular and over the crack ($5000). The third was to shotcrete the entire basement foundation ($50,000). The third contractor suggested that if he was me (with little experience, limited funds, and no access to the same types of professional tools), he’d put a new wall in in front of and spanning the compromised segment of foundation and atleast a few feet around the corner.
All of that being said, I intend to construct a wall as suggested and for several reasons. (1) All tools and supplies required don’t cost all that much. (2) It is a permanent and reliable fix suggested even by a professional. (3) The fix doesn’t have to be immediate so I can gather supplies and tools over time and I have the means to transport said supplies. (4) I have the ability and the will to go through with the extensive labor that it requires.
Thank you for your time and please take the time to comment if you have it.
