First of all, I wish all of you good strength and patience to overcome this bad situation with coronovirus
I am electrical engineer in the electricity company in Cyprus. I confess that I have no experience and knowledge in this matter.
I look forward to your kindness in answering my questions below:
Why do I measure voltages of the output terminals (secondary of isolating tranformer to earth ground? there is no connection to the earth...!! there is something missing....!! I did't understand...!!
I have an isolated transformer 2kVA 800V/230V. I am measuring as below:
between two terminals (not directly on the transformer output but on a MCB, 1m distance): 232V
between one terminal and earth: 175V
between the other terminal and earth: 49V
note: the primary of this transformer 800V/230V is the two Phases output (secondary) of a three phase transformer 22kV(Delta)/800V(Star).(the neutral - site of 800V - is grounded).
other question: If I have a small generator 230V without connection to earth will i measure voltage between the outputs terminals and earth ground? if yes ... why..???
I need your help to undertand this measurments.
I will appreciate it
Thanks in advance
Best regards from Cyprus Kyriacos
