In order to be level with hall, I need to raise the height of the floor by 1/2"-1" in a room in which I am going to be installing vinyl plank flooring.
Previously the room was carpeted so with the padding it was not as obvious a difference in levels.
The floor is concrete.
What are my options for bringing up the height of the floor ? Can I use foam board, or do I have to use Hardy Backer or DenseShield Or something else ?
Thanks
  • Need more info here. Is this a house or apartment, what is the other floor made out of, do you have a layout of the are with openings? Also do you have a link to the vinyl planks you want to install?
    – DMoore
    Apr 9 '20 at 19:49
  • What does the manufacturer have to say about it?
    – Ack
    Apr 9 '20 at 20:06
