This is a 8 x 5 bathroom floor on the second level. The wood subfloor seems to be in good condition, no movement, solid. One section all of the old thin set that came up very nicely. The rest of it was a bear and I could not get it up at all whatsoever and seemed to possibly have something like self leveler over the thinset. We already primed it with the intent of putting floor leveler on it but am having second thoughts. I believe the largest variance from the lowest part to the highest part maybe a quarter inch. we realize that the floor leveler will be pretty thick in some areas. Is there a reason this is not recommended? We intend on putting down a heat mat, thinset finishing with large 18 x 36 ceramic floor tiles. Thank you.
  • Thickness and area size of old thinset ? "We intend on putting down a heat mat, thinset finishing with large 18 x 36 ceramic floor tiles." You did not mention cement board. Cement board in the low spots, self leveling cement in the voids, then thinset, cement board wall to wall, heat mat, tile ?
    – Alaska Man
    Apr 9, 2020 at 20:46
1/4” is not a problem with all the self leveling compounds I have used, self leveling compounds work best in a large area if you get them close with a wide trowel, I usually mark the edges or use a laser get it in the ballpark and it dose it’s job.
  • Beat me to it.. just about my same answer...+ stay safe out there Ed
    – JACK
    Apr 9, 2020 at 18:49
