I have pocket doors that occasionally scrape on the inside on their frame which scuffs them up.
How should I protect against this?
I was thinking of using the soft side of velcro strips inside the frame.
Sign up to join this communityI have pocket doors that occasionally scrape on the inside on their frame which scuffs them up.
There is a missing guide at the bottom of the door, much like a closet sliding door. Install one and it will prevent the door from moving side to side and it will stay centered and not rub.
Sometimes the guides can be hidden behind the trim, depending on how the door was trimmed out. This makes for a far neater looking installation.
Image that shows proper installation of door guide. Because of the angle, the rubbing will not be on the surface, but on the bottom edge of the door. There also hidden door guides, but these may be specific to your brand.
