There's a leak, most likely a freeze burst, in a vertical section of 1/2" copper pipe that runs behind some drywall. In order to minimize the amount of drywall that I have to tear out, I'd like to locate the burst before hacking up the wall. Is there a way to do this?
  • A better description of the leak would help. Where is it wet? In my experience freeze related "leaks" are violent! I've had 2 and they did a LOT of damage. I suspect a failed connection someplace. If the solder job wasn't done right, it can corrode and start leaking. I've even heard of copper pipe being eaten thru by aggressive water (esp. the cheapest type M copper). That is worst were the water first comes in the house. Commented Apr 3, 2020 at 15:03
Sure, just turn the water back on and wait.
Of course, that won't actually minimize the drywall repair work. But you'll eventually localize where the leak is.
My actual approach would be to point out that a big drywall repair is barely any harder than a small one, so get over that misconception and rip away.
  • It could have been a poorly manufactured section of pipe that has developed a pinhole, so replacing as much as possible, as you recommend, would be a very good idea to avoid future problems. Commented Apr 3, 2020 at 16:34
  • yeah, with a drywall repair you, ironically, spend most of your time waiting for stuff to dry.
    – Jasen
    Commented Apr 4, 2020 at 19:33
If you are really dedicated to avoiding replacement of a sheet of drywall (see other answers), then drill a small hole near the top of the run, and insert an endoscope or equivalent. Lower it slowly until you see where the drip is occurring. Cut there.
You can get USB-powered & connected scopes like this for peanuts at the usual shopping places online.
If the leak has been going on for a while and is bad enough to allow water to spray out sideways so it hits the drywall (instead of just dripping out slowly and traveling down the pipe) you just need to gently but firmly probe the drywall with your fingers until you find a soft spot caused by the drywall absorbing the water. Since it is already leaking there, your drywall is getting wet and will almost certainly grow mold and mildew, so you will need to replace a it anyway. If the leak is spraying out at an angle so you're hole isn't exactly at the leak, it won't matter since you needed to patch that spot anyway, but you should also be able to look through that hole to determine whether you need to move up or down.
  • There was water flowing through it for at least a few minutes at one point and there aren't any water stains so I'm inclined to assume that the hole is big enough that it's not spraying out, which would be consistent with the theory that it was caused by a freeze burst, if I'm not mistaken.
    – intuited
    Commented Apr 3, 2020 at 15:04
  • A freeze burst can be large enough that it puts out the same or more than a shower...
    – Solar Mike
    Commented Apr 3, 2020 at 18:33
