I noticed in late February that even immediately after washing my hair, it felt and looked greasy and that my bath water felt as though it had a bit of bath oil in it. The town water department thought that it might have to do with my water heater.
Before I got around to having it flushed, I noticed that it was leaking from the bottom. I had it replaced on March 17, but the problem persists.
The town tested my water on March 30. Yesterday they told me that all was normal, except that the hot water was a few points higher in Ph level. The cold water is 7.something, while the hot is 9.something.
I can't figure out what would be causing this, and it's a nuisance! So, I'm trying to find out what would cause the ph level to be higher and what can be done about it. Thanks!
