I started using a power washer in unison with a pole with a heavy metal edge on it. It's going tremendously slow. My question, if I rent a concrete grinder from Home Depot, would that remove this top layer of aggregate?
pebble stone aggregate overlay
I have not removed a overlay but I have put a few down and if the epoxy was dry in that area it might come up easy with a pressure sprayer but a section that has plenty of epoxy will be a bugger to grind, a commercial tile chipper it is like a heavy pole blade that cycles back and forth it will probably do a better job.
| improve this answer | |
