I live in Southwest Florida, and we have well water. I am in the process of redoing our whole well input plumbing setup and wondering about the best materials to use.
This is what I'm proposing as a flow/materials:
- The well pump pumps up water in a PVC pipe, which right past above ground transitions to a steel pipe. (Currently setup from the old system)
- This steel pipe goes into a steel Tee that has one side go to PVC for a sprinkler system, and the other side of the Tee goes into the ground utilizing metal, and once underground transitions to PVC. (Currently setup from the old system)
- That PVC runs about 4' to a Well Shed, where it pops back out of ground utilizing steel, and goes into the shed.
- Once in the shed there is a pressure tank, pressure switch, sediment filter, iron eater, and kinetico softener. All of these I'm imagining connected with PVC.
- The ~115' run to the house is done in Endopure Poly tubing.
- This transitions to steel to feed into the house above ground.
My questions (For all of these I'm looking for the best answer from a lasting / maintenance standpoint. I don't mind if its a little bit more expensive):
- Do you think I should replace any of the materials being used in steps 1-2?
- Are there any materials besides PVC that you'd recommend I use for step #4? Everyone around here seems to use PVC, but it seems like PEX might be easier to work with and might last longer. I do have this in a shed, so it should mostly be shielded from UV.
- Is something like Endopure the right / best thing to use for step #5? Most people I know use SCH 40 PVC for this; but it seems like poly is supposed to be more durable / better.
- Anything else you'd change / recommend from a materials setup?
Thanks for your feedback!
