I recently had a large truck back into the aluminum gutter on my garage and tear it open. What is the easiest way to repair this damage, please?
Replacing the whole gutter seems like overkill, but maybe attempting a patch is not feasible?
I've used Bondo from 3M for gutter repairs. It's a two part fiberglass filler that will bond well with aluminum and plastics. It sets quickly and can be sanded in a few hours.
Just bend the aluminum back in place to support the Bondo. You mght want to use some duct tape on the inside of the gutter to hold it together. I would do the inside first and let it dry to give it structure and then do the outside.
Sand and paint.
From the tear it looks like aluminum. I'd bend all the pieces back into the original shape and then fill in the cracks and skim coat the area with some J B Weld. This stuff works great. It can be sanded to smooth it out and then painted to match your gutter and is completely resistant to water.
