I bought a house a few years ago and am finally getting around to working on the irrigation system.
I have what I believe are two separate wells for outside water - one for the irrigation system and the other for a few spigots around the yard. I am in central Florida - I believe that matters regarding well type/depth?
Here is the well for the irrigation system:
The top of that is about 6” below the ground level. Although it starts up and I can feel the ground vibrating around it, I don’t get any water from it. Could there be anything I’m doing wrong, or does feeling the ground vibrate mean that it is definitely running and needs to be pulled to investigate?
EDIT (5/5/2020): After pulling the pump up about 4 foot and lowering it back down, it now slowly pumps out a steady stream of very dirty water. The foot valve seems to work fine - it starts putting out water immediately when turning it on, so it's not leaking back down, at least not quickly.
Am I safe in assuming that this points to a dirty/clogged filter at the bottom? And is the only fix a pull and clean?
Here is the well and pump for the second one:
This one has a pressure tank, unlike the irrigation well. I’ve tried priming this one via the priming plug and by back-feeding the spigots. The water that I put in gets pressure-fed back out to me, but I get nothing more. Could I have a blocked pipe?
EDIT (5/5/2020): I determined that the tank had a bad bladder, so I'm going to replace that. After letting the pump run for a long time, it does bring water up, in cycles. It will start to pump out water, and then it stops for a few seconds. This cycle goes on forever.
Does this cycling point to an issue with the pump or with the well?
