My Makita cordless saw has stopped working. I have replaced the brushes and armature. With the brushes removed I have 19V at the holders. With the brushes inserted and in contact with the new armature the reading is 22mv. I am not an electrical engineer so I do not know if this reading is correct. There is no hum or suggestion that the armature will turn.Regards Gordon Clamp
1Hello, and welcome to Home Improvement. I'm guessing this is off-topic here, but more info might help. And, you should probably take our tour so you'll know you'll know the details of contributing here.– Daniel GriscomMar 29, 2020 at 12:24
1Much though I like to fix things (and recently brought a vacuum cleaner back to life that presumably left the factory with the dent in its brush holder that stopped it running, that I was able to un-dent and clean up so it worked again) your error, IMHO, was not binning the tool and buying a new one at the point where new brushes didn't fix it. I don't know how much you have spent, but I know that I don't consider replacing the armature cost effective on my circular saw, .vs. getting a whole new (or used) one that works. As it happens, I spent $15 on a used one...– EcnerwalMar 29, 2020 at 14:16
1It could be the battery under load is bad or the switch I check those prior to replacing an armature.– Ed BealMar 29, 2020 at 15:34
Hi Ed, tried several batteries that work on my other Makita tools also I assume the switch is ok as it shows on and off on my meter. I would normally agree with you Ecnerwal, I already have a brushless Makita saw, I purchased the one in question with an angle grinder and battery as a job lot. I was after the angle grinder, I am just trying to get the saw going as a hobby. Regards Gordon– Gordon ClampMar 30, 2020 at 13:15
Add a comment
