I have been going around the replacing the old caulk where it was cracked on the insides of my windows. I came across this window and it really opened up when scraping away the old caulk. It's by far the biggest gap so far and I'm guessing needs more than just a re-caulk. I stopped scraping after the first bit, got a little worried. As you can see in the photos, the insullation is visible and the wall flexes quite a bit.
Photos: https://ibb.co/album/hfDAOv
Is this a big issue or can I just fill it with a different product? Would something like a foam backer rod work here?
Thank you
It looks like it has been there since the dry wall was mudded and not something new. I would not expect water damage to look like that. I don't know what is the reason for the wall flex or if it is excessive. More than likely it was either a poor fit of the dry wall during installation or these are newer windows that were narrower than the originals. I suggest filling in with 'hot' mud which is a chemical set dry wall mud that is fast setting and won't shrink and crack
