I would like to 3D print something that fits into this threading:
pipe
For that I would need the exact measurements of that thread, but without knowing what the standard is called it's hard to look them up.
Edit: As requested in the comments, I have measured the pitch, it is about 2.3 mm.
    Then you also need to measure the pitch ie how far from 1 thread to the next...
    – Solar Mike
    Mar 28, 2020 at 17:52
    @SolarMike I could probably manage that, but is it really necessary? If I go to the PVC pipe fittings aisle in the hardware store they only have one pitch and it always fits.
    – AndreKR
    Mar 28, 2020 at 18:12
    Well off you go then...
    – Solar Mike
    Mar 28, 2020 at 19:10
    @SolarMike Done.
    – AndreKR
    Mar 28, 2020 at 19:19
  • Is it metric or NPS (national pipe thread) ? It could be 2" NPS. "Taper" is another critical dimension. I believe NPS is in ASTM A450 also in ANSI but I don'e know the section. An EU document would be needed for metric. Mar 28, 2020 at 20:15
