I'm trying to figure out the best approach for this issue I ran into. So I have a door jamb that sits at 79.5" wide and the actual frame is at 79.25" wide.
I have 3 options:
trim either the hinge or doorknob side down. Cons: Weakens either the hinge frame side or the passage latch will have to feed into the wall stud in the frame.
trim the frame entry, Cons: harder to do, chances wont be a clean cut, thou can be hidden
take 1/4" off the top of the door frame and door itself
I cant decide which one I should do. Would love some advice on what you thoughts around this are.
