I have an alarm system that I'm going to fit myself, the motion sensors will be mounted in the corner of the rooms - presumably as the screws are relatively short (maybe a 1 to 1.5 inch long) this is a worry-free exercise and things like wires will generally not be an issue?
It's a new build property in the United Kingdom if that matters, thank you.
    You need to layout your plan, get your equipment and then ask specific questions about specific problems you're encountering. This isn't a general forum.
    – JACK
    Mar 26 '20 at 14:11
    Wires ? Who uses wired systems these days? I agree with jack you should have the device it may use self adhesive pads to mount.
    Mar 26 '20 at 14:21
    When you set the alarm make sure the cat is out... :) guess how I know...
    – Solar Mike
    Mar 26 '20 at 15:39
    In a properly built house, 1" screws should not reach any wires inside the wall or ceiling. You will want to be careful drilling if you are installing anchors.
    – Alaska Man
    Mar 26 '20 at 15:42
  • @JACK the specific question was whether or not I needed to be aware of electrical or piping works behind a wall if I am using 1-1.5 inch screws, this is clearly in the topic of my question. Mar 26 '20 at 18:01
