I've removed the carpet on the stairs from 1st floor to 2nd floor. There is hardwood under but half the boards are cracked all the way across and deflect noticeable when walked on. I'm debating what all to do to them. I'd like it to be safe, look good and not squeak.
The stairs are 34 inches wide and there is no center support. The house was built in 1954, there aren't stringers, only individual blocking nailed on each side for each stair tread. There doesn't appear to be enough room to put a center stringer in between the ceiling below and the underside of the stairs.
I'm leaning towards replacing at least all the treads, maybe the risers too. Can I stiffen them somehow if I can't get other support under them?
The front few inches of one stairs was not attached, that's the only access to look at take photos that I have.
Thanks!
The only board in the middle looks like a 2x4 on it's side and does not touch the stairs as far as I can tell.
  • Can you provide a picture of the supporting members? I want to see the blocking and front and back of the step area. Ideally this would be with one off the treads off but also could be from below, however you were able to observer the area. I need to know what is there to better offer a solution. Also, is the total depth of the tread there now 3/4"? Or?
    – Ack
    Mar 25, 2020 at 22:29
That structure is adequate for a couple reasons:
  • The risers carry most of the load. They act as beams and support the front of the tread, where most of the weight lies.
  • 34" is a fairly short span by modern standards. You can't even build stairs narrower than about 42" these days and meet code.
  • Those treads are really strong. Breaking an oak board like that takes a heck of a lot of weight, even when split.
I would simply repair what's there. Countersink about four screws into the nosing for each tread. Liberally apply wood glue or construction adhesive and mount them back in place. Cap the screw heads with oak plugs, touch them up with a sander, then stain and varnish.
If you want to replace the treads, oak ones aren't going to be cheap. An alternative would be particle board, which doesn't look terrible when stained and varnished. They're about 1-1/8" thick and would be plenty strong if glued down to those risers.
  • Thanks. I'm wondering if maybe they were separate pieces on each tread that are no longer even/attached. The tops are 2 color from an old carpet runner, most have paint splatter or paint spots, etc. I was thinking replacing would be better, both for look and the split (or originally 2 piece) boards
    – user20127
    Mar 26, 2020 at 0:47
  • I would think that adding 1 1/8" treads where a thinner tread was previously would affect the total rise and end up with a problem at the upper landing. If the existing treads are about the same you may be fine, but the allowable variation in height of rise is limited. Mar 26, 2020 at 1:22
    @JimmyFix-it - If the replacement thicker threads were still supported by the existing blocking there should be no real cumulative effect. The only difference should be the bottom step is a tad bit higher and the top step is less by the same amount. If the treads increased from 3/4" to 1 1/8" the difference in the two places would only be 3/8".
    – Michael Karas
    Mar 26, 2020 at 10:50
  • The current treads are probably right at an inch, so not much difference. Even if they're 7/8" it's not too bad. I seriously doubt that they're 3/4".
    Mar 26, 2020 at 14:36
If you see that the treads are what is giving and not the blocks supporting the treads, as isherwood says, there is no need for a center support, precisely for the reason he stated. Many stairs are built without center supports.
When I have my preference as to how I want to build stairs, this sketch illustrates my joining method. enter image description here
All tongues and grooves are 3/8"X3/8" The groove under the tread since it is thicker 1 1/8", will leave plenty of mass to keep the nose intact. In your old tread, it looked as though the treads were glued up, but that glue joint failed, unless all are made that way... The idea is the groove will allow the treads to be better supported by the risers and when glued will prevent squeaking. The groove under the tread will allow a little give and take in the differences of the some of the risers, treads too, which will typically happen in hand made construction, if not by the differential shrinking of the support members.
If you have access to a table saw, I make the dadoes (grooves) by getting 4 or more blades the same diameter and stack them up on the saw arbor, if the saw has a cast iron arbor, until I get the width of cut I need. This is limited by the size of the cutout in the throat plate, but 3/8" should be attainable. Do not do this with a light weight portable saw. Clean the original supports so the adhesive can be applied there to so nails will hold everything together until the glue set up. Stay off the stair system if possible until the glue sets go the glue tightens up all the joints. If the joints are moving before the glue sets, it will be a weak joint and may move again.
  • Thanks! Right now I'm leaning towards keeping the risers and replacing the treads. Watching several YouTube videos I'm thinking dados and rabbits are great but not totally required? I have a router I could use but not a table saw I can put a dado set on.
    – user20127
    Mar 26, 2020 at 23:07
  • The joinery I show allows for complete engagement of all components. But joints like the original will work too but will rely more on the fasteners. The glue spreads the strength over a longer surface as where nails only connected in places where it is nailed, The more nails or screws are used then become a possibility of splitting the material since each fastener act like a wedge to a degree. If you do clean everything and glue the joints it will still be good. Have a solvent handy for your glue, the grooves in my detail control the glue movement. Gluing on the existing surfaces will be messy
    – Jack
    Mar 26, 2020 at 23:36
