I want to connect this washing gun to a hose end (1/2") with a quick connect system. What connector do I need? Any links would be welcome!
For instance, would any of these work?
    On this side of the pond hose bibs are 3/4 npt threads but have an oring or washer seal , the threads do not actually seal the washer or o ring does that the threads pull it tight. I would expect the same in your neck of the woods and would expect any hose fitting designed for quick disconnect to work. A plumbing store could probably give you the fitting in about 10 seconds to make sure you don’t buy the wrong part on line.
    Mar 25, 2020 at 15:21
  • @EdBeal Sure, the problem is that shops are all closed due to Coronavirus situation. That's why I would really appreciate a link or the name of the part at least. Mar 25, 2020 at 20:35
Ok I figured out your sizes the gun takes a 1/2” BSPM thread Your link the male adapter 2.70 pound (your dollar? ) is the right one but there are 2 sizes FQCBM2 is a 1/2 BSP fitting so this should be the correct size. I hope this gets you all set up it looks like it should from both descriptions.
