I'm trying to do something that should be really simple - clean the filter in my GE Triton dishwasher, which won't drain. It has this screen that covers most of the bottom of the dishwasher, and I need to remove this screen to get to the filter in the back. But the screen is attached to plastic posts with these metal objects - I don't know what to call them, but they look like they are designed to go on once and not come off.
The plastic posts appear to be part of the base of the dishwasher and they don't budge. I have pulled pretty hard straight up on the screen and these things don't come off naturally. I've gone at them with a pliers with no effect. Is there a trick to removing these or does it have to be destroyed?
I've found one youtube video where someone removes the same screen and it doesn't appear to be attached at all, so I assume this was installed in a non-standard way. I definitely have to remove it to get the screen out.
