I’m attempting to replace the vanity mirror in my daughter’s bathroom. The old mirror is wired for electric lighting, but the new mirror is just a mirror with no attached lighting fixture.
My question is, when I remove the old mirror, do I simply cap off the existing wiring and the hang the new mirror in place of the old, or do I need to remove the wires completely? It would be nice to keep the existing wiring in case we’d like to add lighting in the future, but my first priority is safety. Any advice would be most welcome.
  • How is this mirror mounted? Mar 24, 2020 at 23:54
If the wires are installed in a junction box, then wire nut them separately, wrap some electrical tape around them, insert them back into the junction box and cover the box with an approved cover plate. If they are just dangling out of a hole in the drywall/tile, then you need to find out what junction box they come from, probably a switch box, and disconnect then there. Wire nut and tape them and maybe leave a note explaining what they're for.
  • Thank you so much for this. Once I remove the old vanity I will take the necessary steps depending upon whether there is a junction box behind the old mirror, or if they are traveling from elsewhere. You absolutely answered my question. Thanks again.
    – Geoff
    Mar 24, 2020 at 22:40
By code the junction box must be accessible, if you read the definition of accessible as applied to wiring methods “capable of being removed or exposed without damaging the building structure or finish or not permanently closed in by the structure or finish of the building”. So wiring methods located behind removable panels designed to allow access are not considered permanently enclosed and are considered exposed as applies to wiring methods.
What is this saying? You can make a fancy cover to hide the junction box and save it for later use. I have been doing this for years using Velcro strips to hold my little picture frames in place, one day an inspector asked me to open one as he liked my little picture frames in a basement that allowed access to the ugly 4x4 j box cover(s). I pulled a bit two quickly and broke 1 side before the Velcro released, he said I could screw them in and did not have to be no tools (as I had thought for years) but as long as the finish was not messed up on the wall I could use screws.
I still use Velcro except with very large covers old habits you know ,, but as long as the box is accessible you don’t have to remove it. If you want to close in the wall and abandon it the wires do need to be isolated from power and tagged or removed.
If it were me I would keep it accessible and cap the wires put the cover on and make a frame or hide it behind the mirror as a possibility for future use.
  • What a great idea with the Velcro straps! I might have to try that on a few access panels around the house. You’ve certainly answered my question and I really appreciate it. Thank you!
    – Geoff
    Mar 24, 2020 at 22:42
