Just put in the shower floor tile with epoxy adhesive & have the perimeter tiles left to do (the very bottom tile against the shower floor tiles)
What Adhesive can I use for this? Is it ok to use thin-set tile mortar or should I use Epoxy?
2nd question ; What kind of grout should I be using for the shower floor?
I would use the Thinset tile mortar for those tiles. I would use the epoxy grout for the shower floor and the rest of the tiles. There is a difference between the epoxy adhesive and epoxy grout, make sure you get the epoxy grout.
    Thanks very much! Perfect, just what I needed.
    – user113678
    Commented Mar 23, 2020 at 20:56
