My husband installed a new Moen faucet. The drain appears to be raised more than the old drain which is causing the water to stand around the drain. Is there any fix for this?
    Pictures are always worth a thousand words.
    – JACK
    Commented Mar 21, 2020 at 20:48
    Is the seal in the right place?
    – Solar Mike
    Commented Mar 21, 2020 at 20:54
  • what does a faucet have to do with a drain?
    – jsotola
    Commented Mar 22, 2020 at 18:25
There are usually a few different rubber seals or gaskets that go on the drain pipe before installing it into the sink. Make sure to use the thinnest one so the drain will be low. If you did use the thinnest one and the drain is still too high, get some plumbers putty from your home store and form a bead of it and wrap that around the drain instead of the rubber seal and then install the drain pipe. You should be good to go. stay safe where ever you are.
