Is it safe for me to be in an attic with this type of insulation without a mask? Insulation I have found myself coughing whilst laying floor boards and I’m not sure whether that is general dust or something to worry about? Thanks in advanced...
  • To be honest, I have no idea... I do know that this house was only built around 4-5 years ago however. Thanks for your comment :)
    – M Vallance
    Mar 21, 2020 at 15:22
Generally, it's safe to be in an attic with fiberglass insulation without a mask. Is it a good idea? No. It can get into your lungs and cause the coughing you're experiencing and can also irritate your throat. the coughing you're experiencing is probably a combination of the fiberglass and the dust that settles from the venting of the attic. Do yourself a favor and wear a mask.
@Chris Rodgers mentions about how much stuff adheres to a mask after just a short while and that reminded me of a photo I took last year after being in my attic for about an hour installing a whole house fan.
    I’ll go out and see if I can find one in the hardware store then! Thanks Jack.
    – M Vallance
    Mar 21, 2020 at 15:24
    @MVallance in general, that's a great idea. With the current COVID-19 panic, masks are tough to find. For your purposes and for short-term exposure to dust and fiberglass fragments, you can likely get away with using some sort of bandana type arrangement. You're trying to keep dust out, not viruses.
    Mar 21, 2020 at 20:05
  • Yea, there was none in the hardware store... ridiculous... I ended up using a micro fibre cloth attached to my glasses! Not sure how effective this actually is, but I guess it’s better than nothing!
    – M Vallance
    Mar 21, 2020 at 20:20
  • T-shirt ninja mask is easy to make and should work pretty well for the larger particles. Also shields skin!
    – jpa
    Mar 22, 2020 at 5:24
As @JACK points out, do yourself a favour and wear a mask.
Small particles of the insulation along with dust can be flying around and that will get worse whilst moving about in the loft/attic space. When wearing a mask you will be surprised how much is stuck to the filter or mask itself after a short while and that will be in your lungs and throat without it.
If the material is rock wool, otherwise known as mineral wool, it can potentially cause lung problems
    No particle is great to breath. Saw dust is carcinogenic. Fiberglass has issues too including "Bronchiolitis obliterans. Styrene is a toxic chemical used as a resin in the production and installation of fiberglass. Construction workers exposed to styrene are at risk of developing bronchiolitis obliterans, a rare disease in which the walls of the smallest airways thicken and become obliterated. This is a devastating lung disease with no known cure other than lung transplantation." Mar 21, 2020 at 16:37
