I have tiled walls around a built in enameled tub. The tile itself (4x4) is in excellent condition. However, there are a lot of gaps in the grout, from half an inch to two inches in length, scattered around.
The tile job was done about 16 years ago.
I like the tile and want to keep it. (It is pretty.)
Should I strip out all the grout and regrout the whole thing? Or is it OK to just push some grout into the gaps?
Thanks!
You could push some grout into the bare areas but even if it was original from the same bag it will now be a different shade. I usually strip the grout for a level but not the entire wall I might cut just a slight amount on everything and when filling the bare areas work everything so the color matches or is not as obvious. After 16 years I probably would not be looking for flexing in this case and a refill will probably be fine.
    How best to remove the existing grout? Mar 17, 2020 at 4:49
    @JonesomeReinstateMonica You can get a tile grout saw at your home store.They're about 5 to 10 bucks. Get a dust mask too.+
    – JACK
    Mar 17, 2020 at 13:10
  • I prefer a saw , some use dremel tools but 1 slip and there is a scar on the tile, the saw is slower but you don’t need to cut much out and grout is soft.
    Mar 17, 2020 at 18:45
