Generally speaking, is it a good idea to fish low voltage cables through a plumbing chase?
I want to specify that I was wondering about using the same cavity (A plumbing chase), not using the actual plumbing vent (DVW Pipe) itself.
Sign up to join this communityGenerally speaking, is it a good idea to fish low voltage cables through a plumbing chase?
Yes you can run low voltage and even mains voltage in the same cavity your plumbing is using.
I say this with the understanding that the cable is rated for the chase construction (some made out of brick / concrete the cable would have to be listed for use enclosed in brick or concrete).
