Has anyone replaced their swamp / evaporative cooler's existing thermostat with a smart WiFi-connected thermostat like Nest or Ecobee?
I want to know if there are any differences in connection or operation I should be aware of. I do not need to install relays, switches or other parts.
Thanks.
  • No, what I needed to know was if there are any problems replacing an EXISTING thermostat which already controls a swamp cooler with a smart one like Nest or Ecobee.
    – Mr B
    Commented Mar 17, 2020 at 4:05
  • Thanks for the reply. Would you edit your question to clarify the difference between yours and the alleged duplicate? Commented Mar 17, 2020 at 11:11
  • Question already states, "Replace existing swamp cooler thermostat with smart thermostat." I want to know if there are any differences in connection or operation I should be aware of. I do not need to install relays, switches or other parts.
    – Mr B
    Commented Mar 18, 2020 at 21:27
  • Saying "I do not need to install relays, switches or other parts" won't change what you'd actually need to do. And, I've edited out the "shopping" portion of the question; it's off-topic here. Commented Mar 18, 2020 at 21:39
  • We would need to know if your existing thermostat is millivolt or 24 volt for example. The nest can control your swamp cooler but you may need to add a transformer, so yes it can control a swamp cooler where a simple mercury bimetallic thermostat is being used. However nest is not millivolt compatible so a transformer / relay may be needed but without more knowledge of your wiring we cannot provide a complete answer.
    Commented Mar 19, 2020 at 11:47
