Insulation R value only relates to conducted heat. Foil-facing reflects heat, so it reduces heat transfer between inside and outside via another mechanism (stops radiant heat from becoming conductive heat). Comparing foil-faced and non-foil-faced insulation of the same R value, the foil-faced will reduce total heat transfer more.
I'm in a situation where I may need to replace foil-faced insulation with another type that is not foil-faced. I can match the R value, but would lose the foil's reduction in radiant heat transfer. That would translate to more conductive heat, which could be offset by increasing the R value.
Is there a way to figure out what increase in R value would yield equivalent reduction in heat transfer as the foil adds (i.e., maintain the same temperature difference between inside and outside as the foil-faced insulation)?
    It will be a change in the radiant heat transfer, not conducted heat if the only change is a lack of foil... A good book about heat transfer is By Simonson.
    – Solar Mike
    Mar 13, 2020 at 7:22
  • @SolarMike, my understanding is that radiant heat gets reflected or absorbed. If it's absorbed, it get converted to conductive heat.
    – fixer1234
    Mar 13, 2020 at 8:36
  • This might be a question that better fits in Engineering. engineering.stackexchange.com
    – Ack
    Mar 13, 2020 at 16:35
  • @Ack, if this was a theoretical question, Engineering might be a better site to figure it out. But I'm hoping this has already been figured out and there are existing, practical solutions ready to be applied by contractors and DIYers.
    – fixer1234
    Mar 13, 2020 at 18:46
The layer fields on the professional Ubakus-Site allows to input also metal foils, so it should take the reflections into account. But those reflections do only have a tiny effect if the subject is building insulation. Much more important is the fact that metal is a barrier for waterdamp. And in general, wet insulation material decreases the insulation effect. So in reality, removing a metal foil could improve the insulation.
  • Disclaimer: I do not have any association with that web site, I do not benefit/profit in any way from my recommendation of that site. It is just by far the most professional and sophisticated site to calculate and visualize the relevant insulation parameters that I have found up to now. For DIY the free access seems to be ideal. But I can't tell anything about the commercial option since I do not have access to it.
    – xeeka
    Mar 14, 2020 at 8:41
  • Thanks for the response. That web site was a challenge--so much is in German (even with the English setting), and is based on the European model (U vs. R values). It mentions radiant heat but didn't seem to factor it in (or I couldn't figure it out). That said, I suspect you're right that the foil doesn't add much in my case. It's in a basement, so radiant heat probably isn't a big factor.
    – fixer1234
    Mar 14, 2020 at 15:41
  • I did not check all input fields, but the most important seemed to be translated. Switching to R instead U value is done by clicking on the tool symbol next to the U value. If radiant heat is not taken into account for metal layers, I assume it does not play a role in buildings - only it does as water damp barrier.
    – xeeka
    Mar 14, 2020 at 17:00
