Wondering why the cold water comes out with full pressure but warm is at 1/4 of the pressure?
What are all the things I can check?
Sign up to join this communityWondering why the cold water comes out with full pressure but warm is at 1/4 of the pressure?
If it's only that one sink it very likely is caused by corrosion or blockage between the shutoff and the faucet. The hot water side is especially susceptible to scale buildup. There are a few basic things to check:
If the hot is a separate faucet:
Remove the aerator from the faucet. Clean the screen of any debris.
Turn off the hot shutoff valve and remove the hot water cartridge and check it for scale buildup.
If there is still a flow issue I would replace the shutoff valve and/or the hot water cartridge starting with whichever one looks most suspect. This should solve your problem.
Edit
Another possible cause, but less likely, is galvanic corrosion which happens when two different metals are connected such as galvanized pipe coming out of the wall connecting to copper. This requires a special type of connection (dielectric union) to prevent corrosion.
