I have a system that requires 16A and 240 power volt, however we only have 10A wall outlet power amperage available.
If you need 240v @ 16 amp then that is 3840 watts of power;
power is in units of watts and mathematically (generally speaking) is W = V x A.
If your circuit breaker only allows for 10 amps @ 240v then that's only 2400 watts of power available. You're short 1440 watts so depending on what you are looking to do you are probably going to need a new outlet installed and wired to provide 240v rated for 20 amps.
I did consider connecting two transformers in series across two 240V 10A wall outlets to produce 240V 20A
I cannot readily picture that wiring, but a transformer is used to convert AC voltage to some new voltage such as 120v to 240v, or 240v to 120v, or 120v to 5v (usb phone charger) etc. And in doing so, the given transformer is only rated to deliver so much power. For example if you had 240V @ 10A that is 2400 watts of power and to keep the same amount of power at 120V there would need to be 20A. Any transformer will have a power output rating, you are looking for 3840 watts of power and I don't thing you are going to find anything for consumer/residential use at that power level. Not to mention you already have 240v available, so you don't need a transformer. Your problem is not enough amperage available which using a transformer will not solve.
Aside from having an electrician come out to install a 20A wall outlet, are there any convenient or more versatile solutions to this issue?
Doing this would provide the simplest means (and probably safest) of getting the necessary amount of amperage at one outlet for use. With nothing other than electrical wiring in mind (somewhat considering your in Australia and however they do electrical down there) it sounds like you have all 10 amp outlets to work with at your location so you would simply need is wiring from 2 separate 10 amp outlets that are on the same phase from your load center panel then run in parallel to your load to provide 20 amps; this would be the most convenient (inexpensive) way of making use of what you have available but since you said I am not especially electrically minded this is something you should not do yourself and would be better to refer this info to someone else technically competent and knowledgeable about doing something like this.
I've heard of Uninterruptible Power Supplies but am unsure if that would help here
it might depending on how long you need 3840 watts of power for. What will happen is you only have 2400 watts of 240v power providing 10 amps to charge the UPS. If you pull 3840 watts from it you will be discharging that UPS and that will only last for however long. Repeated heavy draining of a UPS like this will not help it last long, a UPS rated to deliver that much power may not be available for residential/consumer and certainly would not be cheap- it would probably be best to get a 20A outlet installed instead.
consider buying a cheap generator powered by a single cylinder gasoline engine. They are typically rated at 5000 watts output capable of ~7000 watts surge, and they provide a 240 volt outlet which i think is rated at 20 amp.
