I ask this question here as all results from my searches relate to installation of regular carpet, not carpet tiles
I'm tidying up a small laundry room under a stairway. I will be installing carpet tiles (50cm x 50cm vinyl-backed carpet tiles) and some skirting/baseboard. Should I install the carpet tiles first, then the skirting board on top? The arguments for doing it the other way around with regular carpet don't seem to make as much sense for carpet tile, which can easily be removed by lifting it from the centre and it does not have a tack strip.
